Thread: Never shocked......but boatmen & backswimmers here
    Sep 2010
    South Mississippi
    27
    Ok-started w really sunny hot drought conditions....chlorine levels fell (&CYA)s I didn't pay close enough attention to it...then WATER-BUGS arrived & I knew I had issues....cranked up the SWG from 50% to 75%-killed(squashed all biters & non biting water bugs)Finally got rain these last 3 days(overcast) in a row- Now here are my numbers-any suggestions
    FC-8
    CC-0
    PH-7.8
    TA-50
    CH-360
    CYA-40
    salt-3300
    20,000 Freeform IG Gunite,Gray Plaster,Tanning Ledge w 2 Bubblers, 8f tRaised Spa with 8 jets,Fiber Optic-3 ft Sheer Decent, 1 ft Sheer Decent, Intellibrites, 2 HP Jandy Stealth Pump, 1 HP Jandy pump, 340 Jandy Cartridge Filter, Jandy Aquapure Salt System, 2-1HP Blowers....and promised but not yet delivered Rheem 105 BTU Heat Pump/Chiller
    West Michigan
    108
    Re: Never shocked......but boatmen & backswimmers here
    Read how to add borates to your pool. Since I've had it in my pool I've never had a water bug. But I'm sure the pro's will have something to add about your numbers too.
    5 years 18' Intex Frame pool, July 2009 upgrade, 28ft rnd used Doughboy, 1hs Hayward Power Flow pump, Doughboy DE filter.TF test kit
    nutjob's Avatar
    May 2011
    Dallas
    109
    pH could be a bit lower.
    My own experience with backswimners matches kimrst's: ever since I started maintaining borates in my pool they nasty little bugs have kept away.
    Correlation, yes. Causation? Don't know.
    I laugh—to disguise the tears.
    Size 15,000 gal 510′² | Filtration DE 48′² | Sanitation SWG+O₃ | Placement in-ground (IG) | Finish pebble
    Pumps Intelliflo VS+SVRS main WhisperFlo WF-28 feature | Location Dallas TX US (33ºN 97ºW)
    Sep 2010
    South Mississippi
    27
    Thanks guys.....yea would love to hear from the pro's here. Was wondering about the borates. Wasn't sure if the low chlorine caused the bugs or if algae was suspect.....
    30,426
    any suggestions
    What does your water look like? If it's not crystal clear, how long has it been that way?
