Results 1 to 12 of 12
Thread: Fountain with multiple configurations -pics and video-
    Here are a few pictures and a video of a pvc project I've been working on, since I'm not very good at DIY stuff I re-created a few different pieces 2-3 times until it was exactly what I wanted. I didn't come up with my final idea/plan until I had already tried to create something different. It didn't turn out great, so I reused some segments and re-made it. This is probably the 3rd overall attempt and I'm finally happy with it!
    YouTube Video
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: Fountain with multiple configurations -pics and video-
    Looks like Star Wars!
    Jun 2010
    San Antonio
    424
    So what did you do to make the different water flows?
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    That's pretty cool. Did you make the diff nozzles interchangable or were those just your different designs you tried out?
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Quote Originally Posted by woodyp
    Believe it or not I never got in to star wars, you would think I would have (if you knew me).
    Quote Originally Posted by Txmat
    I should have mentioned, it's my 2 speed pump.
    Quote Originally Posted by Jamison04
    I ended up with 4 pieces, the part that connects into the pipe is an L shape, I made another piece that's a "lazy L" (which is what I used for the single jet) and there is also the "bar" for spraying and the two jet attachment. I should take a picture of all the parts disconnected. (probably will this afternoon) All attachments show are the "final products," the nozzles are actually from the pool store (the return jet fixture) the only one that isn't is the "bar," which has holes drilled in it.
    Aaron
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    Like you I'm trying different designs. I've made one from PVC drilled out and am not quite happy with it. Looking to refine the design a bit. I've found that with the fit of the PVC not glued allows me to change the angle or swap out heads. I like the idea of having diff options
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    VERY NICE!
    18x52'' intex AGP, 6981 gal, 2650 intex sand filter,
    thru wall skimmer, SWG, 52'' 20G overlap liner, intex pool light
    Yeah, I'll go snap a pic of my different pieces, I used a bunch of threaded connectors so I can swap certain pieces out, I thought if I didn't glue them it might pop apart, but I never tested without glue.
    Quote Originally Posted by jsf0656
    VERY NICE!
    thx
    Aaron
    DaneCE's Avatar
    Jul 2011
    VA
    279
    More fun with PVC.
    So cheap and so easy to design different shapes. My son wants me to make a giant water curtain next.
    water curtain sounds pretty cool!
    Here is a pic of all the different parts.
    Here is the inspiration for the dual jet attachment.
    Just kidding, actually I came up with the idea after trying to make something similar to what crookm11 made.
    I have yet to use the plug and remove one of the two jets, but I'm sure it wouldn't be any different than using the two connector pieces, but it would shoot a bit higher.
    Aaron
    les_garten's Avatar
    May 2011
    PSL, FL
    153
    I'm gonna bump this thread that is just in time for Summertime temps in S. FL.
    Great High quality documentation and idea here!
    A few questions:
    1) Do you have any ideas about the temp advantage using this gadget?
    2) Did you run it at night and see if it made a big difference? I think it might.
    3) How much did your acid use go up?
    Thanx!
    I also sent you a PM.
    14x30 PebbleTec(Caribbean Blue) 12,000 Gals BORAX
    Pentair IntelliFlo <<>> Pentair FNS Plus DE
    Pentair 5G Intellibrite w/Intellibrite Controller
    ROME Solarium 125 Heat Pump
    Kreepy Krauly Classic <<>> Pentair 320 Feeder
    Last summer we had many weeks of 95+ sunny and extremely humid days (probably even 10 consecutive days). Running the fountain all day (7:30am-5pm) it was able to keep the water in the upper 80s, 87-89. I overheard other people's pools were in the 100s. I never ran it overnight. (which would have lowered it considerably more)
    I can double check my spreadsheet when I get home, but I'm fairly certain the pH increase was around 0.2ppm/day. I used the single jet attachment.
    Aaron
