Results 1 to 8 of 8
Thread: If I don't have a a heater. Is a check valve ..
    installed between the filter and the salt cell a necessity? thx, SR
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: What's the purpose of installing a check valve..;
    To prevent back flow of highly concentrated chlorinated water into the filter. The highly chlorinated water in the cell dilutes quickly when it reaches the body of the pool, but should it back flow into the filter and stagnate (such as when the pump is turned off) it could be strong enough to cause damage to the filter over time.
    Love TFP? Become a
    TFP Supporter!
    Thx, Zea3, Do you think its a necessity?
    It depends on how far from the heater the SWG is. The closer together they are, measured in pipe length, the more important it is. Many brands just want three feet of pipe between the heater and the SWG. Pentair is a little unusual in asking for a check valve. Of course if you have a Pentair brand heater, leaving out the check valve can void your warranty.
    Thanks for the reply. I do not have a heater. So by not having a heater, does that negate the need?
    Hey folks, have held off on plumbing in the salt cell until i can get a couple of opinions on this check valve issue. Understanding that I don't have a heater, is the check valve necessary. thx,SR
    Re: If I don't have a a heater. Is a check valve ..
    It all depends on what you call a "necessity". Pentair says you have to have it. Most pools don't have it. Draw your own conclusions.
    Mar 2011
    441
    No, its not needed the concentrations of chlorine created by most salt systems are very low.
    20X40 30,000 gallon gunite pool
