Results 1 to 7 of 7
Thread: How to operate the diverter valve?
    Thanks to this amazing site, I decided to fire the pool company and take care of the pool myself. I am so happy I did it! I already found multiple issues and the pool is looking great.
    There is one basic question that I am not sure about: how to operate the diverter valve. My question is: where should the OFF position on the handle be for:
    (1) Skimmer only?
    (2) Main drain only?
    (3) Combination?
    [attachment=0:209lob9u]photo.JPG[/attachment:209lob9u]
    Right the OFF position is on "B" and I am not sure it is the right position. Also - there is a plastic pin that blocks the handle from going all the way to OFF at "C" - not sure why.
    Thanks for helping a newbie!!!
    Guy
    ~20k gallon IG plaster pool, Pentair 3/4HP Whisperflo, Pentair FNS Plus 48 DE filter, IntelliClor IC40 Salt Generator, Pentair Legend Platinum Robotic Cleaner
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Re: How to operate the diverter valve?
    Welcome to TFP!
    1: Off should be at the C pos.
    2: Off should be at the A pos.
    3: Off should be at the E pos.
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    You can take the pin out if it is in the way.
    Thank you so much! This is an awesome site!
    Guy
    One more question: where is the 80% skimmer/20% main drain position?
    Thanks!
    Guy
    22,542
    Close to where it is in the picture. With "off" a little more toward "C".
    If you want to *understand* your diverter valve, turn off the pump and take the valve apart (probably only a few screws holding it together). You'll likely see that there is a "door" that covers/uncovers the various pipe openings as you turn the handle. On mine (and I'd guess on yours, too, by the presence of the "off" tab), the "door" is opposite from the handle (resting against position "B" in your photo). So with the handle over position "E", the door is completely covering the inlet from the skimmer (position "A"). Of course, I could be all wet if your valve is constructed differently from mine; I'm by no means an expert in pools and equipment! Especially since Mark Crook's responses don't seem to agree with what I just wrote (just noticed the discrepancy - maybe someone can fill us both in?)
    Disclaimer: if you take your valve apart, make sure to keep the inside C-L-E-A-N! Bits and pieces along the seals can cause leaking when you reassemble). And if you're the least bit unsure of your mechanical aptitude, don't take it apart!
    No sig yet, but 30,000 gal vinyl in-ground-with-billions-of-$-wasted-last-year-listening-to-the-pool-store-before-I-found-this-site-and-got-a-real-test-kit-and-learned-real-pool-chemistry-now-I'm-loving-every-minute-of-saving-and-splashing.
    Phil
    North Central Ohio
    30k rectangular vinyl in-ground pool
    1.5HP , sand filter, Hayward SWG, propane heater
    motorized solar cover, In-floor cleaning jets
