Thread: 2 Speed Motor
    2 Speed Motor
    Why would I want to run the higher speed motor on my pump?
    Thanks!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: 2 Speed Motor
    Several reasons, to mix in chemicals quicker, and more efficient vacuuming to name two. Also if you have water features running off the same pump you may want to run them at high speed so they look more impressive when company comes! Roof mounted solar panels may require a higher speed setting, ymmv.
    Love TFP? Become a
    TFP Supporter!
    Re: 2 Speed Motor
    The four most common reasons to run the pump on high are priming the pump, backwashing the filter, coating the grids on a DE filter, and vacuuming.
    Re: 2 Speed Motor
    Thanks so much...I will try it at the higher speed for vacuuming and backwashing....
    Re: 2 Speed Motor
    also, some people enjoy the jet pushing them while floating around the pool
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Jul 2007
    Northern NJ
    299
    Re: 2 Speed Motor
    Would you recommend running it on high for shocking, too, or just what was previously mentioned?
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
