Thread: I am a new owner of a 27' 17,000 gallon pool
    Hello, I am a new owner of a 27' 17,000 gallon pool and very little knowledge about pool care. I have been trying to find a solution to my problem by reading these forums, but have had little luck. So I am asking for HELP! Since starting the pool 3 weeks ago, the water has been crystal clear, but my PH has been at 8.4 and my TA at 240. I haven't messed with it much this whole time because we have been working on the deck and haven't been swimming . Ready to swim now, I shocked it 2 days ago and the water became insantly cloudy and has not cleared up. My levels this morning are FC 5, PH 8.4, TA 240, and Stabilizer 30-50. I only have the test stips that came with the pool. Do I need a different tester and what should I do to clear up my cloudy pool problem?
    Re: I am a new owner of a 27' 17,000 gallon pool
    Welcome to TFP!
    First, get the PH down to around 7.2 to 7.4 as soon as possible. You always want to keep the PH below 8.0. There is a reasonable chance that will clear up the water.
    It would be a huge help if you had a better test kit. I recommend the TF100 from TFTestKits.net. The Taylor K-2006 is also good.
    It is also a good idea to do some reading in Pool School.
    Thank you. I have a container of Ph down, is that all I need to add? I will for sure be ordering that test kit you recommended.
    22,548
    We recommend muriatic acid but since you already have it, you can use the dry acid (pH Down). You can use the Pool Calc to figure out how much you need to add.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by allsix99
    Welcome to TFP
    You can use the pH down to lower the pH. Use the PoolCalculator.Com to figure doses.
    Since you only have the strips, I suggest you take a water sample to a pool store for a full set of test results. Then we can go from there.
    Ditto on the TF100 test kit. Best investment we made in our pool. Link in my sig.
    Pls add your pool and equipment specs to your sig.
    You're done SLAMing when:
    Love yourself and add the speed stir and the sample tool!!!!!!!!!!!!!!!!!!!!!!
    -Tom
    17,000 gal plaster with spa. Pentair Clean & Clear cartridge filters. Jandy systems with Aqualink RS and Polaris 360.
    Pool Store free since May 2011!
