Thread: Replacing the suction side pipe
    Jul 2010
    Pardes Hanna, Israel
    64
    Hello All,
    I am about to replace my suction side pipe using rigid PVC, crossing the back yard from skimmer to pump and in effect making a 180 deg. turn.
    I have two possible ways of doing it and was wondering if there is a difference.
    The upside of the second option is less digging... but I can't decide which of the options presents less resistance to flow.
    Some "ASCII art" to illustrate the issue:
    1. 3 segments, 2 x 90 deg. joints
    2. 4 segments, 2 x 135 deg joints, 1 x 90 deg. joint
    Code:
    Pump        Skimmer       Pump       Skimmer
     |_____________|           |__________/
            1                        2
    Appreciate your input.
    Yoav.
    15 KL (3300 imperial / 4000 US gallons) IG fiberglass pool, 61cm (24") Lacron sand filter, 3/4 HP Hayward pump
    Re: Replacing the suction side pipe
    If you actually mean two 45 degree bends replacing a single 90 degree bend where you said 135 degree bends but drew something closer to 45, then it comes out about even either way. Two 45s are about the same as one 90. If you actually meant 135 degrees, one 135 is worse than a single 90, and two 135s is much worse than one 90.
    Jul 2010
    64
    That's why I made the drawing - I knew the 135 would be a confusing description.
    I guess then its a matter of convenience now.
    Yoav.
