Results 1 to 12 of 12
Thread: what would cause this........
    Jun 2010
    Dayton, Ohio
    241
    My pool is clear but not holding chlorine level. I put 5 96oz jugs in today and two hours later it read that there was none. My cya is 50 I will post other numbers tomorrow. I just thought it really weird and I have no clue what to do. It has done this for two weeks. Not registering that I pour bleach in it. What could be causing this?
    AGP: 24' x 52" cartridge filter: 13,500 gallons. Taylor K-2006 test kit.
    DaneCE's Avatar
    Jul 2011
    VA
    279
    Re: what would cause this........
    Quote Originally Posted by passionsrlz
    Possible poor quality bleach...3% or simply too old.
    False test results
    High amount of organic matter in water.
    ...what else??
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Many things could cause that situation, including low CYA. Likely you will need to shock, but we'll need a full set of test results 1st. Also you may perform the overnight FC loss test, if your water is clear
    Jun 2010
    Dayton, Ohio
    241
    I will buy some higher end bleach, I always buy the cheap stuff and have never hand an issue. But this is crazy wierd. Last I checked CYA was 50. What could cause that to go down?? I am sooooo confused.
    CYA usually only goes down when you replace water and sometimes when the pool is closed for the winter.
    Jun 2010
    Dayton, Ohio
    241
    No replacing water and water level holding steady. Just not keeping bleach. I had an algae bloom earlier this year and when I poured five bottles of bleach in the water two hours later it still had some. I am showing none at all......very frustrating.
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    How are you testing?
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    Jun 2010
    Dayton, Ohio
    241
    I finally have good test kit! So I hope I can trust my results.
    Jun 2010
    Dayton, Ohio
    241
    could I have a bad regent? I left it in the heat and it is really really got here right now.
    Back to the bleach, please put 1/4 teaspoon bleach in 2 gallons of tap water. Test FC of tap water alone and bleach and tap combined. Will need FAS-DPD test for this, using drips, not strips or other color based test.
    22,553
    Please post a full set of test results so we can see everything in one place. That'll give us a better idea what's going on.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    You could have bad reagent. I did one year and didn't realize it until I used a different, newer test kit one day. My FC results had been consistent, but lower than I thought they should be, like around 2 ppm. Newer test kit showed FC to be closer to 5 ppm and that was closer to where I thought it should be, based upon the amount of Cl I was using.
    Just my experience. YMMV.
    Good luck.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
