Thread: Lost the manual
    Lost the manual
    Help, I have lost the manual for an Intex above ground pool with swg, and with all this heat my swg is reading low salt after adding more and running the pump , i have build up on the cell and do not know how to sevice it, can anyone lead me in the right direction. Please.
    22,553
    Re: Lost the manual
    Clean the cell with a mixture of water and muriatic acid 4:1. That should take the buildup off it.
    Re: Lost the manual
    Thank you. having lost the manual. i am going to assume that the few screws will release the cell after all necessary elec, pumps are off etc. ?
    Re: Lost the manual
    The cleaning procedures vary a little from model to model. If you post a photo or tell us any brand/model name that might be printed on the unit we can give you much more specific advice.
    Re: Lost the manual
    18'x48" Intex metal frame pool, 1600 Intex sand filer/pump combo, Intex SWCG.
    Apr 2010
    Las Vegas
    173
    Re: Lost the manual
    I have two of the 8110 models from '09. The manual states to use viniger to clean it. I se 4:1 water/pool acid(30%) stuff. cleans in 10 mins.
    Watch your TA mine was 150 and i had to clean my cells every 5 days. There is a water chemistry chart for SWG's here under pool school.
    20,000 gal. 32' x 17' freeform custom pool, 3ft. shallow - 8ft. deep end, Pentair Whisper flow 2.2 HP WF-6, Purex/Triton Nautilus FNS48 DE filter, 2 Intex Chlorine Generators (retired) SR Smith Rouge Rapids curved slide, The Pool Cleaner 4-wheel model w/Hayward large leaf canister. Tightwatt pool timer Spa: Beachport 5 person/350gal. Wishlist: move Neiko Tools pump to slide, solar system, Fountain, Automation. http://www.poolcalculator.com/
