Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Please Help!!!
    Please Help!!!
    I am getting sand in my pool? We have changed out the laterals...even though there was no cracks in the old ones and the sand is still coming in...We have checked all of the gaskets and replaced them...How can it get into my pool...We have a old pool...the Filter is a sand TA60...I hope someone can help me
    San Juan Inground Fiberglass Pool 17x33 (2008) year it was put down
    Tagelus Sand Filter (TA60)
    Pump...Hayward 1 horsepower
    Closed for years needing repairs...Repaired last summer 2010 and reopened
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Please Help!!!
    Welcome to TFP
    How long ago did you replace the laterals?
    Pls list your pool and equipment specs. You can go ahead and put those in your sig
    You're done SLAMing when:
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Please Help!!!
    btw, are you sure it is sand? How does it feel? Generally, sand will feel gritty, pollen usually feels squishy; and algae feels slimy.
    Re: Please Help!!!
    We just replaced them yesterday...
    We have a San Juan Fiberglass pool....Large, I am not sure of the size but it is 10 ft. deep
    Tagelus Sand Filter (TA 60)
    Re: Please Help!!!
    How do I fix a sig.... The pool is 17x33...It is probably around 25 yrs old...Had set for years needing repairs...We did that last summer and had a little sand coming in the pool but not as much as we do now
    Feb 2008
    Denton, TX
    5,061
    Re: Please Help!!!
    There are several things that look exactly like sand under water but instead, are often algae, pollen, or dust. How does this stuff feel? Does it feel like sand?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Please Help!!!
    Quote Originally Posted by Hope54
    Go to "User Control Panel" (top left under TFP logo), select Profile, then Edit Sig.
    Re: Please Help!!!
    It is sand...no doubt !!!
    Feb 2008
    Denton, TX
    5,061
    Re: Please Help!!!
    My first choice, even if it has been replaced, is a lateral. Second choice is gasket. That's is really all it can be unless someone can think of anything else.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Please Help!!!
    Well, the only idea I have is possible channelling. But, since you just changed/rearranged/cleaned the sand when you replaced laterals, I doubt that could be the issue.
    Has the sand always been coming back into the pool, since 2010 repairs, or did it just start recently?
    Re: Please Help!!!
    It didn't come in during the early years of use...but did some last year and more this year
    Re: Please Help!!!
    Which gasket would you think it could be? Hubby has replaced all of the gaskets
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Please Help!!!
    So, sounds like it started after the 2010 pool repairs, correct?
    Please add your pump info in your sig.
    Folks will be reading and needing that info to see if your pump/filter combo are playing nicely together or what
    Others will be along with some ideas. Don't worry. It will get fixed
    Re: Please Help!!!
    ok...sure will...
    Re: Please Help!!!
    I don't remember it having sand in the pool in the earlier days...if so, only a small amount...
    Thanks for your replies...We are just pulling our hair out trying to figure this out
    Re: Please Help!!!
    I have even More sand in my pool today than yesterday
    30,408
    Re: Please Help!!!
    How much sand did you put in the filter when you replaced the laterals? In other words, are you certain the sand is at the correct height in the filter?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Please Help!!!
    Check that the center stand pipe is seated well and there are no cracks. You can pull out the sand again and make sure the latterals are still ok as well.
    Love TFP? Become a
    TFP Supporter!
    Re: Please Help!!!
    It is over 2/3 full of sand...is it possible to get to much and that cause a return sand problem in the pool?
  20. Back To Top    #20
    Re: Please Help!!!
    Hubby did check the pipe good before he put it back in, but is planning to pull it all out again...
