Results 1 to 8 of 8
Thread: salt water testing
    salt water testing
    Question about salt test strip's,on bottle it say's to 1. place strip in water
    2.wait 10 min.
    should u hold under water for 10 min. or just dip?
    Also my SWG Is telling me salt is low 2600
    but i dummped 10- 40 lbs. bags= 400 lbs thats for a 12,000 gal. above
    test show's 5000 if iam doing it right.
    24' AGP sandstone,12,000 gal , cricupool rj30 SWG,fas-dpd test kit. BBB
    Feb 2008
    Denton, TX
    5,061
    Re: salt water testing
    Just dip. Wait 10 minutes for it to result after you take it out.
    What brand of salt test strips are you using? The AquaChek strips get left sitting in about 3/4" of water for around 4-5 minutes.
    It can take salt as long as 24 hours to mix in, and as much as another 24 hours for the SWG to fully register the change and show the correct salt level.
    yes aquacheck,ill wait and try again tomorrow because i put salt in this morning.
    Re: salt water testing/ updated with pic.'s
    findly got the circu pool Rj30 working,Idiot me,unit kept tell me water default,so i check the mauel and it siad low water flow or salt level,i had reel good water flow and salt test show 5800 on aqua strip. (10- 40 lbs bags fro 12000gal.) unit keep say's 2500.So i decided to check conn. on cell again,and after close inpection i notice i had blue wire and black rev. .
    Now its salt test show's 5000 and it's producing clhorine.
    here are my nums. as of this morning before working unit.
    fc- 15 been dumping bleach daily
    ph- 7.2 -was 7.1 put some ph up yesterday,may put more late?
    TA-250
    CYA- 50 ish
    salt- 5800 aqua strip / SWG saying 5000 probly ill need to add water to pool with in a couple days.
    I would like to say thanks for the help on TFP and some of the earler post's i have been reading,
    also thanks to discount salt pools for calling me back with in 5 min. from message on a sat. to resolve the problem with 220v. to convert too 110v. they talked me through it .
    i will post pics of set up if anybody has for any input. phil
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    572
    When I use the test strips, I put about an inch of water in a shot glass. Works great.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    thats what i did,it is a bout 800 off the unit but i just got it goning so ill wait see what happen's.
    sun. afternoon
    FC-35 - up 15 even after rain storm,turn down to 20%
