Thread: Liquid Stabilizer
    Liquid Stabilizer
    My stabilizer is 0: can I use liquid stabilizer for a faster result? Does it need a week to work as the powder does?
    Intex Metal Frame 24'X52" agp, Intex 2500 gph filter, Krystal Clear SWG, Pool Calculator, Taylor K-2006,
    Mar 2010
    Spring, TX
    1,082
    Re: Liquid Stabilizer
    No liquid stablizer will work similar to how bleach works. Add it and test in about an hour and you should be good to go. It is a lot more expensive, but if you need it like now it is what works.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, it is pricey. You might want to consider dichlor if you need both CYA and FC.
    You're done SLAMing when:
    Feb 2008
    Denton, TX
    5,061
    +1 on the dichlor. It raises your CYA quickly and it much cheaper than the liquid CYA is. Plus, you have the added benefit of chlorination to boot.
    donaldm823's Avatar
    Cape Coral, FL
    147
    I have used liquid in the past and 1 gal gives me 10ppm for a 30K pool. But last week I used the CYA crystals, only I poured 1 lb of cystals into a skimmer that had a skimmer sock installed. The crystals disssolved in less than 1 hr and I had 4 lbs added in 4 hrs. My post test Taylor showed that CYA increased the expected 16ppm. Watch out for the pH drop as mine dropped 0.2 pH units. BAsed on the ease of using the skimmer sock, I will use the cystals again as they cost less than half the liquid for the same amount of CYA ppm change. 1gal liquid ($30) vs 4lb of CYA ($18)
    Don SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter, Pentair SWG, Pentair Intelliflow VS pump (11018)
    FAFCO solar panels w/Pentair SolarTouch controller
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
