Thread: Can topping off affect FC Level
    Mar 2010
    Spring, TX
    1,082
    If I did the FC test and then filled up and topped off the pool, could this affect my FC level and drop it? I assume it can because I have tested my top off and it has not FC in it and 1-1.5 CC in it.
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Can topping off affect FC Level
    Quote Originally Posted by mynewpool
    Thanks.
    How long did you circulate before testing?
    Possible testing error. Suggest you circulate some more and retest.
    You're done SLAMing when:
    Yes of course it will. It's expressed as parts per million of the water ..so if you add water you are diluting the chlorine.
    Glenn - Pickering, Ontario
    Circa 1980 Vinyl In-ground 80,000 Ltrs. ~ K2006 Kit ~ Hayward Pump/Navigator/Sand Filter ~ Raypak 255 Gas Heater
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by Butterfly
    Thanks.
    No error in testing. I tested last night and had an FC level of 3.5. I topped off the pool but did not test again. Pump was running all night and when I tested this morning to add bleach I got a result of 2.5. Typically I lose .5-0 overnight, usually 0 in most cases unless it was really windy or a lot of rain put dirt in the pool. So that is why I was asking. The person above me answered my question though.
    Thanks.
    Butterfly's Avatar
    South Carolina
    10,045
    Sorry, mnp, I misunderstood your post.
    Do a search on "chloramine" to see a recent discussion in post titled "pre-algaed water" or something like that.
    The tap water is treated with chloramine rather than just chlorine, that is what appears as CC on the test of tap water. It is more stable than chlorine for muni water needs. So it comes with a mix of ammonia and chlorine from the tap, as chloramine. Chem Geek said, if I understood correctly, that the chloramine will consume some FC to eliminate the ammonia part. So, if you added rather a lot of tap water compared to the pool size, you might see that effect.
