Thread: Intellichlor Installation Links/Instructions?
    Thanks folks for all the responses up to this point. I'm getting ready to start installing my IC-60/Power Center. I've read both the instructional manuals, but could someone point me to an instructional link/how to on the steps to install. I'm searching the forum currently, but if you already know where some good ones are I'd appreciate the help. Also I read a couple of posts reagarding installing some sort of cutoff valve between the filter and the ic-60. This is the first I've heard of it and am don't have/don't know where to get the part. Is it necessary? Thanks to the posters so far that helped me pick my unit, JasonLion, susa, bobodaclown.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Intellichlor Installation Links/Instructions?
    My opinion is that it is a good idea to have unions between all the major equipment on your pad. It makes it much easier to remove a component for repairs/replacing than having to cut pipe. So a ball valve union between your filter and ic-60 would provide a shut off point for water and enable you to unscrew the connection to the plumbing at that point. Do a google search for "ball valve union", or check any good plumbing supply outlet.
    Love TFP? Become a
    TFP Supporter!
    Quote Originally Posted by zea3
    Thanks. I did the search and understand the concept but I'm not any sort of pool expert. If I needed to replace the cell, wouldn't I just turn the pump off, unscrew and replace? thx, SR
    Not trying to be a smart*****...
