Thread: Issue with high speed jets
    Hello! What a great site for information...which I am in need of. I have a 2003 Freedom Spa (Master Spa) and the high jets are set to automatically kick off after 15 min. In the past, you could just press the jet button again and they would come back on for another 15 min. Now, the high jets will not come back on for about 1/2 hour or so. The user control panel was replaced about a year or so ago and the tub worked fine for a while after this repair. There are no fault codes listed on the user control panel and everything else functions normally. PLEASE HELP!! THANKS!!
    May 2011
    The Netherlands, Europe
    49
    Re: Issue with high speed jets
    I would contact the supplier or salesperson. Reason for not turning on again could be something like overheating I think. Will prob. go from bad to worse. Good luck!
    Sunspa Monaco in the garden since March 2011.
