Thread: Testing TA, when to consider color change complete?
    FastCougar's Avatar
    Jun 2011
    Eastern Panhandle of WV
    99
    I'm currently lowering my TA with PH lowering and aerating and I have a question about my testing methods. I have a speed stir with my TF-100 kit and when it's dropping in 009 reagent (wiping between drops), there is a transition period between green and slight pink were it's a faint tint of purplish grey. Usually the next drop makes it a very faint pink and the following drop makes it a bright pink (like when adding in 871 to test for FC). My question is at what "phase" do I consider the shift to occur and stop counting drops? It says when turns from green to red, but there is that purplish grey and then faint pink ... should I be going till it's solid pink (no faintness) and stop or should I be stopping at the faint pink and consider that the shift point?
    16,000 gallon 27'x52" Above Ground Pool
    Hayward XStream CC1000 Filter w/1HP Pump (hard plumbed)
    My Build Thread
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Testing TA, when to consider color change complete?
    Here's a link to Extended Test Kit Directions :
    extended-test-kit-directions-t25081.html
    You're done SLAMing when:
    Aug 2010
    Dallas, TX
    4,052
    When you add one more drop and no change occurs, subtract that last drop and what is left is your answer. Make sense?
    FastCougar's Avatar
    Jun 2011
    99
    Makes perfect sense ... test till color stops changing (once red/pink) ... if that takes 14 drops to get the bright pink and the 15th drop doesn't change it, 14 is the magic number. Thanks again!
    My Build Thread
