Thread: New IG pool, air/bubble above water level
    Sep 2010
    Winnipeg, MB
    5
    I hope that I am being paranoid and just a nervous new pool owner, but I have a question about my liner that was just installed.
    I have a kafko steel walled IG pool and the liner was just installed. They used a vacuum and everything looked good. The pool guys had the vaccuum on while the first truck load of water was added (left about an inch of water in shallow-end, then they removed the vaccum and left for the day, while the water truck was on it's way with a second load.
    after teh second load, we noticed that there seems to be air behind the liner above the water level, below the water level is fine, the water pushes it against the sides. When you touch the liner (above the water level) it definately moves in and out. We have since topped up the pool and the water level is about halfway across the border. There is still that air gap between the pool sides and the liner.
    Is this normal and I am just paranoid? Or was the coping installedtoo far out and not flush with the pool side. The air gap seems to be about 1/4 inch. I have attached a diagram. I am not sure of the shape and atachment of the coping, the pool decking is supposed to be cantilevered.
    Any advice/assurances appreciated.
    Pool: 16x32 inground (2011) Experience: Some - With a previous above ground, learning with my brandnew pool
    Sep 2010
    Winnipeg, MB
    5
    Re: New IG pool, air/bubble above water level
    Can't forget the family
    22,553
    I don't think it's a problem. My AGP does the same thing. There's a slight air space between the wall and liner above the waterline.
