Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Avatars
    RAA's Avatar
    Mar 2007
    The Woodlands, TX
    46
    Avatars
    I remember seeing an option to upload an Avatar under my Profile but I can't find it now. Is this a supporter only feature?. Also, if I click my username on the portal where is says "Welcome RAA" I get this message:
    -Rick
    ~15k Gal IG
    Gunite/White plaster
    AquaLogic PS-8 w/SWG
    Try the ideas found in this post...
    Sean has recently added the ability to upload avatars (again)
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    It's fixed now- you should be able to upload. Avatars for some accounts are in fact dissabled. It was going to be a supporter only feature but it was too difficult to administer. I've got to go back and enable the feature for about 150+ users. I'll try to have it done by this weekend.
    On the clicking your name on the homepage, I'll have to work on that. You can click on the profile button though and get the same info.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    RAA's Avatar
    Mar 2007
    The Woodlands, TX
    46
    Ok, I was able to link to it using an offsite url. I was not able to attach it directly and if I try to upload the Avatar from a URL I get this:
    Thanks!
    -Rick
    ~15k Gal IG
    SeanB's Avatar
    Mar 2007
    2,622
    You have to upload it from your own pc - save the file as a jpeg then upload it.
    TFP Founder
    RAA's Avatar
    Mar 2007
    The Woodlands, TX
    46
    Quote Originally Posted by SeanB
    I know what happened. It was the size, it must be =< 6k and 80 Pixels or less.
    All good now. Thanks,
    -Rick
    ~15k Gal IG
    Mar 2007
    Morris, IL
    477
    That happened to me as well. Mine was greater than 6Kb and what I did was select the bottom one, Link to offsite avatar. I hosted it on Photobucket and it worked.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Mar 2007
    Knippa, Texas
    289
    There's still no option for an avatar when I go to my profile. . .
    ~Jules~
    My pool: INDOOR 13x27 rectangular fiberglass, built ~2001, BBB, TA-60 sand filter, Hayward two speed pump (1 hp/0.33 hp), 3/4 hp booster pump for solar heater
    Taylor K-2006 test
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Try it now. I just updated your account.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    I also do not see an option for Avatars when I go to my profile. Can you please "fix" me as well?
    Dave
    SeanB's Avatar
    Mar 2007
    2,622
    OK, your all fixed.
    TFP Founder
    Riles_J's Avatar
    Nashville, TN
    218
    Between the poster Name and Avitar there are a few lines of text. Mine says "I can see the bottom of my pool" ? Can I edit this? If so, where do I do so.
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    Can't be edited... it will change as you post more.
    Just one little way we keep this board fun!
    riverheightsnancy's Avatar
    Aug 2007
    Flemington, NJ
    33
    I cannot upload an avatar. I have resized the pic to 80x53, tried Photobucket and Tinypic. I will get errors that it is not a Jpeg, giff (& some other protocol, that I can't remember) or I will get an error that it exceeds the 5kb requirement. I am unsure how to resize to meet the 5 kb requirement without the pixels becoming all wonky. I usually shoot really with really high pixels quality so that I can look at them quite enlarged.
    Any suggestions for a program to use? I have Photoshop 6, but I can't seem to get below the 5 kb mark, however, I am not an expert in that program.
    Thanks for any help.
    1960s Original Sylvan Pool
    Concrete
    @ 30,000 Gallons
    Hayward DE Filter
    2 HP Hayward Pump
    BBB believer!
    I just used good 'ol paint.exe to resize mine and it worked fine
    21' Round (12k Gallons) AG
    Strong Pools Colosseum Riser 56", 1 hp Sand filter, 10'x12' Composite Deck,
    Auquacal Aerotemp Heat Pump, Also: Sundance Cameo Spa
    See my pool build thread here: Katkami's Pool Build - With time lapse video!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    A high number of colors can really run up the file size. To shrink it, select Image, then Image Size and set the values to the proper size.
    Guest
    Irfanview (excellent FREEWARE graphics software) is a good program for resizing pics. To further reduce the size save them as a GIF and not a JPEG. You will be limited to only 256 colors BUT it should not be a problems given the small size of the Avitar. If you are saving it as a JPEG reduce the quality of it. Once agan, given the small size it's not going to be a problem. Remember, we are talking about an Avitar and not a large picture that we can see a lot of detail in.
    Aug 2007
    Flemington, NJ
    33
    Success! Thanks everyone!
    PS Love reading the newsletter-Waterbear, I always thought you were a woman , You have lead an interesting life!
    Concrete
    @ 30,000 Gallons
    Hayward DE Filter
    2 HP Hayward Pump
    BBB believer!
    Quote Originally Posted by riverheightsnancy
  20. Back To Top    #20
    Guest
    If I am I MUST have a glandular problem to have a beard like I do! Maybe I should double check! Hang on a sec....Nope I am DEFINITELY a man!
    I DO try to stay in touch with my feminine side!
