Thread: Jandy AquaPure 1400 Code 171 and 190
    Help! I have replaced the flow sensor but I still get these codes. I have a single speed 1.5hp pump by Jandy and the cell looks and acts fine. I'm within 2 months of replacing the pump with an Intelliflo SVRS variable speed pump...should the salt system be changed too?
    Re: Jandy AquaPure 1400 Code 171 and 190
    Welcome to TFP!
    A 171/190 error normally means the back board needs to be replaced. However I heard of one case where someone installed the cell backwards and got that error message.
    Thanks! Just to make sure, I went out and checked and the cell is on correctly so now I will search the net and get a new backboard.
    As an afterthought...could this code be coming up because the pool installer wired it incorrectly?
    The only way I could imagine it being because of mis-wiring is if the SWG is not getting the power supply voltage it is setup to expect.
    OK, thanks again! Have ordered the backboard and will have our pool co. check the wiring.
