Thread: 3 days frustration with dirt on pool bottom
    Apr 2011
    Toledo, OH
    71
    First I know it is a given that the intex pumps aren't worth much but the 2500gph (yea right, sure it is) puts out a pretty decent flow when the filter is clean. Here's the problem. For 6 weeks the pool stayed very clear and very little on the bottom, think I used the vacuum 3 times that first 6 weeks. Now the last 3 days I can't keep dirt off the bottom. It may be that it hasn't been used much this week and without all the neighborhood kids stirring the water up the sediment has settled. I have switched the pump to run 24/7 and have vaccumed once and swept the bottom 2 or 3 times each day. What is going on????
    I had to call Intex's customer service right after we got the pool as I had to patch 3 holes I could find right off the batt. Boy the CS stinks. He asked me if I had any sand under the pool and I told him we leved the ground then added some sand to smooth things out. He told me I shouldn't use any sand under the pool and I can expect the liner to rip because of it. I hope all this dirt on the bottom isn't for that reason.
    Oh well, if it is I guess we'll be getting the real pool sooner than later.
    The man on top of the mountain didn't fall there.
    24' x 52" Intex ultra frame pool (12,400 gallons) with seperate Intex 2500gph pump and SWG and 2 Intex magnetic pool lights.
    Looking to upgrade to 27-30' semi inground install
    Re: 3 days frustration with dirt on pool bottom
    Putting a knee high stocking or biodiesel filter bag over the return can catch a lot of the finer stuff that the filter can't. Another thing I do is detach a hose and vacuum to waste. That gets it out of the pool for good and doesn't lose as much water as you would think.
    18'x48" Intex metal frame pool, 1600 Intex sand filer/pump combo, Intex SWCG.
    Do you have a sand filter?
    I was getting sand at the bottom of my pool a few months back. Played havoc with the auto vac. Couldn't think where it was coming from. Although we had not had any significant winds, I thought it was coming from the desert landscaping surrounding the pool until I saw a small pile below a return. It turned out to be filter sand coming through a leak inside the filter.
    Sirena~
    Phoenix, AZ
    35-40K gals; Sand Filter; In Ground; Plaster; Sta-Rite System3 130 GMP.
    Apr 2011
    Toledo, OH
    71
    No sand filter, just the junker stock 2500gpm (250gpm more like) filter pump. The knee high trick looks like it made a noticeable difference.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    That's odd about the "sand will make your liner rip" comment.
    I know we were supposed to get a groovy pad and all... but not a single Intex pool that we've had has ever NOT been on a bed of sand. There's a tarp or two over the sand, yeah... but get this, none of our liners has "ripped", ever. That's just weird to think that sand makes them rip. hmmm... didn't know that. I suppose I should expect it.
    Going on 13 months of pool on a sand bed now. Disaster does not seem to be looming IMO.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
