Results 1 to 13 of 13
Thread: I Just open pool to dirty and green water
    Jul 2011
    New Jersey
    6
    Hello all, I'm new to the site and i have a in-ground 20,000 gal pool, DE filter, just open it a few days ago, its very green and bottom dirty with leaves, i cant see the bottom as of now. I have put a total of 12 /182oz of bleach in pool, and it is getting lighter, and i have a Leslie's DPD test kit, i did a test for FC but no match on the color chart comparator tube, it was clear. I run the pump at night with just bleach in it.
    How much more bleach do i need to clear the green out of the pool? and when will i get test reading from the test kit? Please help im new to just using bleach in the pool,but it is getting lighter.
    Thanks for any help with this.
    New Jersey, 20000gal V Liner, I/G Pool, DE Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: I Just open pool to dirty and green water
    Bad news is: your test kit is inadequate. And now one can tell how much bleach you'll need. A lot of that depends on how frequently you replenish. Each time the FC dips below shock level, algae resumes growing. So it's one step forward and two steps back. Could be twenty gallons, could be 200....
    Best thing right now is head to Pool School and start reading.
    Jul 2011
    New Jersey
    6
    Hi Richard,
    I dont understand why test you say test kit is inadequate, on the label it reads complete Poolcare DPD Test Kit
    Free & Total Chlorine or Bromine, ph, acid 7 Base demand, Total Alkalinity, Calcium Hardness, Cyanuric Acid. Can you Explain why its not adequate
    Richard320's Avatar
    Jan 2010
    19,051
    It's inadequate because it can only read FC up to 5, which is not high enough for shock levels.
    Rather than type a whole bunch, I'll just paste in the URL of the article pool-school/pool_test_kit_comparison
    Jul 2011
    New Jersey
    6
    Thanks much for that info, i now understand why you said its inadequate. i hope i can take it back.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Stupid Leslie's... Second report in a week of selling a K-2005 vs K-2006.
    Glad there's no Leslie's around here. Very glad.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Jul 2011
    New Jersey
    6
    Im going to try to take test kit back to Leslie's today, i was looking to get a good test kit as fast as i can, i need to keep my shock level up at as i clear my pool. I feel im in the dark without the right kit, so should i just keep adding bleach to pool to help clear up the green water , and contuine to clean and remove leaves from the bottom of pool?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    I'd get all the sludge/leaves off the bottom before I started shocking.
    Jul 2011
    New Jersey
    6
    I just became a TFP Supporter today, Im so glad I did, now i can order the correct Test Kit and get my discount. Thanks for all the help, im sure ill need more. im going to order the TF-100, and ill just keep the K- 2005. I did read that you can get an upgrade k-1515A its a single kit that will do the same tests that the K2006 will do. But i will still order the TF-100, its a better bang for dollor. Now back to my green pool, its getting better with just adding 6% bleach, but till i get my TF-100, what will be the best thing to do to keep the geen from coming back?
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    You need to post a complete set of your test numbers so we can see what you have going on. This would be:
    FC
    TC
    CC
    TA
    ph
    CYA- def need this so you can know how much chlorine to add
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Jul 2011
    New Jersey
    6
    Hi pepsiholic,
    I m waiting for my test kit to come, but i will post my readings, i got with my test strips.
    FC 3
    TC
    CC
    TA 80
    ph 7.8
    CYA 30
    I know this is not the best test , but for now its all i got.
    will keep posting on pool, as it gets better, my shock level is FC 13 now. but i must keep anding bleach 6% till its clear. i did read this post turning-your-green-swamp-back-into-a-sparkling-oasis-t4147.html
    this was very helpful, all i can do now is add more shock, and keep checking readings. to all newbees - Get a Good Test Kit first, it will save you a lot of time and money and work, test kit to get is TF-100.
    Jul 2010
    Mickleton, NJ
    229
    Hi from NJ, your new kit will arrive soon, I was surpised at how quickly mine arrived. Once you know what is going on with your pool it is much easier to figure out how much and of what chemicals you need to fix it. Be sure to fill us in on your progress and post pictures.
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Yes, you must bring it up to your shock level and KEEP it there. Only a sustained shock process will turn your pool around.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
