Results 1 to 12 of 12
Thread: whats this look like to you
    Jun 2011
    Nj
    57
    at work
    my numbers are at home
    i have some from the time each pic was taken
    about 2 weeks between each pic
    here is like i said about 2 weeks ago
    and here is the other day
    turned the swg up some
    put some DE in the sand filter
    increased my CYA as it was low
    when i get home ill post the numbers i have
    have not tested since i put in the chemicals yesterday
    11,000 gal inground fiberglass pool
    Aquarite SWG system
    Re: whats this look like to you
    Don't bother to test CYA if you have a number from before addition. Newest won't show on test for a week or more. FC is vital. Is salt level correct?
    Jun 2011
    Nj
    57
    salt level is correct a little high
    3800
    fc when i took to the pool store tuesday night he said was low, i think it was around 2, should be 3-5
    so i turned up the swg
    befor the first pic when i tested it it was more then 1 but less then 2
    i will test again when i get home to see
    Aquarite SWG system
    Jun 2011
    Nj
    57
    ok
    first pic
    7/5
    done with my tf kit
    fc 2
    ph 7.5
    ta 80
    ch 230
    cya -did not get a good reading, could see it the entire tube, a little cloudy but could see
    salt 4000
    second pic
    7/12
    tests done by pool place with fancy stuff
    fc .1
    ph 7.3
    ta 32
    ch 152
    cya 7
    salt 3900
    Aquarite SWG system
    Butterfly's Avatar
    South Carolina
    10,045
    Well, to me it looks like your pool is going from blue-ish to green-ish.
    With the TF100 kit, what is the CC level?
    How much CYA have you added to pool?
    You're done SLAMing when:
    Jun 2011
    Nj
    57
    this most recent time i added 2 lbs
    Aquarite SWG system
    22,550
    2 lbs would raise your CYA by 22 and if you could see the black dot with the tube full, then assume it was about 20, so now it's about 40 and you need to add enough chlorine to bring the FC to at least 5 ppm.
    Once you've done that use your TF-100 to run the FC & CC test and I'd even go ahead and run an OCLT tonight.
    Jun 2011
    Nj
    57
    ok so check my FC when i get home
    use the pool calculator to see see what i need to add to bring FC up to 5
    it says if my fc is 1, to bring it to 5, i need 68oz of bleech, so about 1/2 gallon
    correct?
    now unfortunately i am having people over tomorrow, if i put the bleech in tonight, is it fine for everyone to swim tomorrow?
    once it is at 5, then check DV and CC again?
    Aquarite SWG system
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by *ryan
    correct?
    From 1 to 5, I get 91 oz of 6% bleach. Let's recheck that.
    So, I'd just add a small jug, 96oz, if indeed you have 1 and going to 5.
    Well, we'd like to see the FC/CC #'s first.
    Yes, about 45 mins or so after adding the bleach, retest and post FC/CC results.
    Jun 2011
    Nj
    57
    ok the caluclator shows me 68oz
    no big deal
    bought the small jugs 2 of them 96oz
    ill put 1 in when i get home
    and have it pump threw
    Aquarite SWG system
    22,550
    Did you make sure you have 11,000 gallons as the pool size and 6% as the bleach strength? I get the same thing Butterfly gets.
    Jun 2011
    Nj
    57
    just refreshed and tried again, got diff numbers, odd, pool size stayed the same
    Aquarite SWG system
