Thread: New to testing - TA apparently too high
    I have a 16k gunite saltwater pool. Here are my numbers:
    FC 4.8
    PH 7.8
    TA 130
    CH 430
    CYA 60
    The only one that seems out of line is TA. Is that a problem? How do I bring it down given that PH is OK?
    BBB 26,700 Gal inground Vinyl lined pool with water. Pentair Intelliflo variable speed pump running at 1,500 rpm 24/7. Polaris 360 with booster pump. 200Lb sand filter. Some floating dinosaurs that my 8 Year Old threw in and Hair of the Dog. Taylor K-2006
    Aug 2010
    Dallas, TX
    4,052
    Re: New to testing - TA apparently too high
    When you lower your pH, it will come down some. Unless you have problems like scaling, I wouldn't be too afraid of it.
    That said, your CH is high, so it's possible your TA might allow some scaling issues. You just really have to keep your pH in check.
    Because CH is high, it would be best to work on lowering your TA to the recommended level. The easiest way to do that is to lower PH to 7.2 every time it gets to 7.8. With TA and CH where they are, you need to be careful to never allow PH to go over 7.8.
    Thanks for the responses. So, it sounds like if I am vigilant in keeping PH at the low end of acceptable range, the TA will go down over time. Correct?
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Huckleberry
    Correct.
    You're done SLAMing when:
    FastCougar's Avatar
    Jun 2011
    Eastern Panhandle of WV
    99
    Not sure how often you "top off" ... I haven't been using a solar cover and my pool gets full sun, I'm topping off for about 2 hours (1" of fill) every 3 days or so. I mention this because my fill source has a TA of 250-260
    So, I advise that you TA test your refill source if you are refilling.
    16,000 gallon 27'x52" Above Ground Pool
    Hayward XStream CC1000 Filter w/1HP Pump (hard plumbed)
    My Build Thread
