Results 1 to 8 of 8
Thread: Weird Cloudy Water
    Apr 2011
    South Point, Ohio
    32
    Weird Cloudy Water
    My pool has developed a mild cloudiness to it and at first glance i thought the PH was going to be a little high, but to my suprise it was right on par:
    TC: 7
    FC: 5
    PH:7.2
    TA: 70
    TH:120
    CYA:30
    Could the low TA be causing the water to have a cloudy look to it? Pool calc is calling for Baking soda. Should that do the trick? I left the pump run for 24 hours and that has seemed to help. But the cloudiness is still there.
    24' Round Above Ground
    15,000 Gallons
    Hayward Pro Series 100 Lbs Sand Filter
    Hayward Power Flo LX 1hp Pump
    8 gallon Liquidator 3/8
    BBB Method
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Weird Cloudy Water
    Your TA is perfect. No need to adjust it since your chlorine source is bleach.
    Did you reverse your TC & FC #'s?
    You're done SLAMing when:
    Apr 2011
    South Point, Ohio
    32
    Opps yes i did.
    15,000 Gallons
    BBB Method
    Butterfly's Avatar
    South Carolina
    10,045
    Well, then you got 2 CC and need to start the shock process.
    Detailed instructions in Pool School. Start now/ASAP and your shock level is about 12.
    Post back in this thread w/any q's.
    Apr 2011
    South Point, Ohio
    32
    Thats what i thought the answer was going to be so i started the shock process in between posts.
    15,000 Gallons
    BBB Method
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by mrnick0483
    Thats what i thought the answer was going to be so i start the shock process in between posts.
    Now that's what I'm talking about
    Apr 2011
    South Point, Ohio
    32
    Thank you for your help!
    15,000 Gallons
    BBB Method
    Butterfly's Avatar
    South Carolina
    10,045
    You're welcome.
