Results 1 to 11 of 11
Thread: FC much higher than TC
    Jul 2011
    NJ
    67
    I'm seeing an issue where my FC is much higher than my TC. PH levels are good and CYA is around 35. However, FC is around 10 and TC is around 2.
    This was tested with 2 different brand of strips (I know...) and chemistry is not with BBB. Chlorine is typically added via 3" puck (calcium-based if I recall correctly) in the skimmer. Pool details are in sig. I'm trying to understand how FC can be higher than TC and what I should do about it.
    Intex 15x36 Easy Set (2,800 g.)
    Intex 16" 2650 gph sand filter/pump combo & SWCG
    Intex 800 gph filter just for the surface skimmer
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: FC much higher than TC
    Can't be. FC+CC=TC, so FC will always be less than or equal to TC.
    Jul 2011
    NJ
    67
    Exactly what I thought with my, at this time, very limited knowledge.
    Still both strips (different brands) showed the same thing.
    Quote Originally Posted by George_
    How did you measure your FC and TC?
    FC - Free Chlorine
    CC - Combined Chlorine
    TC - Total Chlorine
    TC = FC + CC
    Your TC will always be equal to FC (if you have no CC) or more than FC (if CC is present in the water)
    76549 Liters -- Cartridge Filter -- In Ground -- Vinyl -- TF-100 Test Kit -- AquaVac Robotic Cleaner -- UV Sanitation -- Winter Safety Cover -- Installed 2010 -- Southwestern Ontario, Canada
    Latest Test Results June 25:
    FC - 6, CC - 0, CYA - 40, CH - 110, TA - 90, pH - 7.5
    Aug 2010
    Boston, MA
    176
    If the strips claim FC>TC, then they're not testing what they claim to be testing. Kind of like a calculator that claims 1+1=5 - if the tool gives a result which is wrong by definition, the fault is in the tool, not reality.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Darn strips! puke (where's the puke emoticon anyway? lol)
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Mar 2010
    Spring, TX
    1,082
    Maybe your FC is 10 and your CC is 2 and TC is 12
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Butterfly's Avatar
    South Carolina
    10,045
    Hi George, I'd say both strips are wrong. Strips are very inaccurate for testing your pool.
    Do yourself a favor and get one of the recommended kits. See Test Kit comparison in Pool School.
    In the interim, you could take a water sample to a pool store.
    You're done SLAMing when:
    Jul 2011
    NJ
    67
    I guess it's possible it should have been labeled CC and not TC on the chart. Other than that....I don't know.
    SW Indiana
    9,199
    Quote Originally Posted by frogabog
    Here
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    LMAO... that's a fast puke (and thick!)
    I wanna puke that fast. Gotta remember to eat before I drink beer perhaps...
