Results 1 to 14 of 14
Thread: How can I tell what kind of Filter we have?
    May 2011
    Jackson, MS
    27
    I'll have photos soon, but is there a general place to look on where the type and make and stuff will be listed?
    Northern who moved to the south and now has a pool!
    25,000 gallon pool - plaster
    Purex Triton sand filter
    22,542
    Re: How can I tell what kind of Filter we have?
    If you don't see a label on it, then a pic is your best bet. Someone will no doubt recognize it.
    May 2011
    Jackson, MS
    27
    Thanks!!
    I've posted a photo of the pump.
    22,542
    Take a picture of the top of the valve.
    May 2011
    23
    Looks like an old Pentair Tagelus or Sand Dollar judging by the multiport valve and location.
    Florida Pool Service Guy
    15k Kidney Diamond Brite
    Hayward C-1200 Cartridge Filter
    Sta-Rite Dura-Glass 1.5hp Pump
    Pentair Rainbow 320 Chlorinator
    Heliocol Solar Panels
    May 2011
    Jackson, MS
    27
    Heres a photo of the top
    May 2011
    Jackson, MS
    27
    I feel silly - I never noticed the Purex triton filter at the very top until now! Do I have any upkeep with this filter?
    May 2011
    23
    I would suggest getting a new pressure gauge, preferably a liquid filled one. Backwash the filter as well as you can (turn that valve 180 degrees and turn on the pump until the waste water is clear), and afterwards, mark the pressure on the gauge when its filtering normally. This is your clean pressure. Backwash it when the pressure rises to 8-10psi above the clean pressure. Sand filters are very low maintenance.
    Of course, this is all assuming that your sand is in decent shape. I'm not sure how you would diagnose the quality of your sand though. You replace the sand every 5 or so years I believe.
    There is no need to replace the sand unless something goes wrong, like heavy calcium scaling of the sand. Cleaning and resettling the sand is a good idea if it hasn't been done in a couple of years.
    22,542
    Ditto what Jason said, but I would replace that pressure gauge.
    May 2011
    Jackson, MS
    27
    Where do I open the filter so the sand is exposed?
    22,542
    You have to take the multiport valve off. Which isn't easy in your case. You'll have to cut the piping. If I were going to do it, I'd cut it in the middle of runs and add unions back so next time it'd b much easier.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    What is that thing to the left of the filter in the first pic?
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    May 2011
    23
    Quote Originally Posted by guamguy
    I don't know the name of it but its one of those ionizing/'purifying'/nature type of things.
