Thread: How long after adding CYA....
    can I add bleach?
    I cannot afford the expensive test kit yet...we took the sample to Leslies and were told to up the CYA, which I did today, but we've been adding a gallon/day for a week and the water is still cloudy. I can see the bottom, it's just not crystal clear. Just wondering if I can add some bleach now, in anticipation of a big Harry Potter party this evening.
    18' round/48" high AG pool
    approx 7200 gallons
    sand filter (large...was used for a 24' round previously)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: How long after adding CYA....
    Welcome to TFP!
    You can go ahead and add bleach any time.
    Thanks!
    And some place I've read to add bleach to skimmer, others say to add where the water comes back in and disperses...which is better?
    22,542
    In front of a running return is the best place to add it. I wouldn't recommend adding a large quantity of bleach to the skimmer though it probably wouldn't hurt anything unless the pump was off.
    Aug 2010
    Boston, MA
    176
    Keep in mind that, in the long run, a good test kit will save you money. Counting on pool store testing is a sure route to problems which will cost more to fix than the kit.
    20k gallon IGP
    Plaster over gunite
    3/4 hp Hayward pump
    Purex Triton DE filter
    TF100 test kit w/ speedstir
    Quote Originally Posted by Beamup
    I know, will do...just need to budget it!
