Thread: pressure difference
    pressure difference
    I had a 1.5 hp pump that was shot and someone else bought a new heyward super pump 1hp .. the original pressure reading on the filter with the 1.5 the perfect reading was 18 psi .. now the 1 hp pump running has never gone above or below 9 psi would this difference be attributed to the difference in hp or is something obviously a little off?
    21X41, 30,000, ig, vinyl,48sf de, 1hp hayward super pump, 2" piping, 2 skimmers, 1 main inlet, 2 return, built in 1988, no enclosure, lots of trees around, direct sun. Thanks in advance to all who have answered my questions.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: pressure difference
    It sounds like a bad gauge. If the pump is off it should drop to 0.
    yes it drops to zero .. so even with a lower hp I should get the same psi in the filter?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by SHADEZ
    A smaller pump will normally give you a lower pressure reading.
