Thread: Water Bonder I help
    Jul 2011
    Hagerstown, MD
    30
    Water Bonder I help
    All,
    Please accept my apologies if this is not under the correct forum topic.
    I need to ask for your expertise. I am a new pool owner as of today, just had our 24' round above ground pool installed today! During the final phase of connecting all of the hoses, filter, etc. we noticed that the "Water Bonder" stainless steel bonding coupler does not fit into the flexible PVC correctly. Let me rephrase, the barbed end is actually smaller than the flexible PVC. So much so that a hose clamp will not work. In the western part of Maryland, we are required to bond the water along with the pool wall to the pump. I would like to use this connector rather than drill a hole in the skimmer thus voiding any warranty on it.
    What have some of you done to utilize such a water bonding contraption? Any type of adapters?
    Thank you all in advance, these forums have been a great source of education!
    24' x 54" Aqua Leader Influence Above Ground Pool
    Hayward Pro Series S180T Sand Filter w/Zeobrite
    Hayward Power-Flo Martix SP1592FP Pump
    Lamotte ColorQ Pro 7 Test Kit
    Aquabot Pool Rover Jr. Pool Cleaner
    All equipment is hard plumbed
    22,553
    Re: Water Bonder I help
    Sounds like you should have gotten the WB-2 and used a plastic threaded adaptor. It says it's standard 1½" hose size so my guess is that flex PVC isn't.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    You can always find some combination of adapters that will work, though it is best to get something designed for what you actually have in the first place.
