Results 1 to 11 of 11
Thread: I need help with finding a replacement light for my pool.
    Hi, I am new to this site. I brought a house with a concrete pool. I sandblast the pool, and I'm about to plaster but I have a problem with the light. The light nitche is empty. Someone cut the light wire. The nitche size is 10 in diameter and 8 in deep. The pool was made by sylvan in the 70's. Can I buy a replacement light which would fit in the nitche? Please help me.
    Feb 2011
    Los Angeles, CA
    18
    Re: I need help with finding a replacement light for my pool
    A picture with a ruler would really help for scale. Hopefully, the light niche will be a standard size.
    18,000 IGP, Pentair VS+SVRS, Pentair 4000 DE, 4x12 Fafco solar panels w/GL-235 controller, Hayward Aqua Rite Pro w/T-Cell 15, Hayward Tiger Shark QC, Guardian pool fence.
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    Yes, if you post a pic of the niche, someone here will probably be able to tell you what brand and model of light you need to get.
    South Central NJ
    3,192
    Please look for any identifying part numbers on the niche. Sylvan used both Hayward and American Products (now Pentair) in that era. Given the 10" size, I would bet a $1 bill that it was an Am-Pro.
    Scott
    Owner of - PoolGuyNJ LLC
    How do I post a picture? Do I need approval from the administration?
    There is no number on my nitche. It was painted over and is gone.
    Aug 2010
    Dallas, TX
    4,052
    Post your picture to a free site like Photobucket, then paste the link in your message.
    Here's an example, be glad you aren't looking for a replacement for this!
    poolplaza.com told me they could help, in fact I need to head over there this week!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Keep in mind you will need to pull new wire, and if it is not in conduit that may not be realistic.
    Aug 2010
    Dallas, TX
    4,052
    Did you try contacting poolplaza.com as I recommended? They can most likely assist you.
    Butterfly's Avatar
    South Carolina
    10,045
    lesj, keep all posts concerning the replacement light in this thread.
    Double posting is not permitted.
    The other posts/threads have been removed.
    You're done SLAMing when:
