Results 1 to 9 of 9
Thread: Just got my test kit
    Jul 2011
    Central Connecticut
    23
    So I've been battling green water for almost a year. Just when I think it's gone, it comes back. I think my problem is that I've added shock and not kept the chlorine level up high enough for a long enough amount of time. So I've kept adding chlorine most days this weekend/week and the algae looks to be dying. The water is still green, but not as cloudy and I can see some of the dead algae on the bottom. Here are my test readings:
    FC 12
    CC 0
    TC 12
    pH 7.2
    T/A 90
    CH 160
    CYA 20
    I've been using trichlor pucks and have a canister and a half left. I'd kinda like to use them up before I try the BBB method. I know they'll increase my CYA, but I assume I need to get it increased faster than that? Should I try to get my CYA level to something like 35 or 40 first, then see where it goes with the pucks and increase it more down the road if need be?
    I was sorta surprised to see my pH that low. I thought it would read high while I was shocking. Should I just leave it for now until I'm doing shocking and see what it reads then?
    Anything else I should do? The rest of the levels seem ok to me?
    24' round above ground pool, 13000 gallons, vinyl liner, Hayward 1 hp pump, sand filter. Extreme newbie - got pool in July 2010 and have battled problems since late July 2010. I vow to win the war though!
    30,408
    Re: Just got my test kit
    jen,
    Don't worry about the pucks right now....put them away but they won't go to waste....promise. Then, just using Clorox, you must KEEP YOU FC AT SHOCK VALUE until your pool gets completely clear. For you shock value is around 10ppm so DON"T LET IT GO BELOW THAT.
    Then run your pump 24/7, brush often and vacuum that dead algae off the bottom. Clean your filter frequently...watch for the pressure to rise 20% or so and then clean/backwash.
    YOur self-diagnosis is almost surely correct....you haven't been keeping the chlorine in there consistently enough but that's all over with and you are ready to clean up your pool (aren't you? )
    KEEP YOUR CHLORINE UP. Don't let it get below 10ppm until your pool is crystal clear. You should see some improvement each day.
    Once your pool is cleared and you have finished the shock process, we can address the other issues but there is nothing serious there.
    Apr 2011
    Lynchburg VA
    393
    Cant stress enough not to let your FC level drop below 10. The better you are at maintaining that FC level the faster your pool will clear.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Jul 2011
    Central Connecticut
    23
    I was going to do an overnight chlorine usage test tonight. Should I wait? I took my pucks out to do this, but I'm thinking maybe I should just put them back in now and get some bleach tomorrow.
    Jul 2011
    Central Connecticut
    23
    Oh, and YES!!! I'm SOOO ready to have a clean pool!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    The overnight test comes after the pool is clear. Keep pouring.
    Jul 2011
    Central Connecticut
    23
    OK, thanks. I'll go put them back in. Tomorrow I'll get bottle of bleach.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by jenlop
    You did mean "bottles" of bleach, right
    Welcome to the forum
    You're done SLAMing when:
    Jul 2011
    Central Connecticut
    23
    Quote Originally Posted by Butterfly
    LOL, yes I did. When I saw my typo, I figured someone would get me on that! If only one bottle would do it.... ha ha
