Thread: white layer of foam
    Dec 2007
    davenport, Fl
    6
    white layer of foam
    Today when I was vacuuming the pool, as I reduced the flow from the main drain and put the skimmer on 3/4 full suction I noticed as i was cacuuming that a lot of gas bubbles were coming from the returns and then the pool filled with whit foam. I have a new aquarite system and have been bringing the pool back from death pond valley. is it okay to leave the swg on while doing so?
    Shannon
    18,000 gallon octagon vinyl liner pool. Sand filter. Main drain closed.
    I would guess that you have a minor air leak in the vacuum hose and otherwise everything is fine.
    Having the SWG on while cleaning up shouldn't hurt anything. On the other hand, I am not sure if it will help much until you can hold some chlorine overnight.
    30,432
    White foam sounds like you may have been using an inexpensive algaecide. If so, it won't help much, if any, in your case. The foaming will go away soon and, while it's just a guess, may well have been caused by algaecide.
