We have a intex 18x42" easy set pool with an intex 633t 2500gph pump. It uses the "B" filters. I also have the skimmer basket installed. We are using HTH 1 inch chlorine tabs in a pool floater and we fill it to the top with tabs. We also use the HTH "shock n swim" shock bags probably once a week.
We originally had the intex 635t 1500gpg pump and it was defective so we bought the 633t and it is WORLDS better. Anyway, so far the only issues ware facing are sand on the bottom of the pool and cloudy water. I bought the Aqua Broom and it is supposed to show up today so I will advise on how well that works.
I hear a lot of people on here talking about using bleach to shock the pool, would that be better then using the HTH stuff? So far I havn't been very impressed with the HTH shock as it leaves residue on the bottom of the pool. If so how much should bleach should I use? Whats the best way to use it?
Thanks in advance!
Jake
Thanks in advance!
Jake
