Thread: Always shock visible algae?
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Sometimes I find visible algae hiding around my ladder. Do I need to shock when I find this? Everything else is pristine.
    FC = 6.0
    CC = ~.2
    pH = 7.6
    TA = 120
    CH = 250
    CYA = 50
    ONCT = < 1.0
    . . . and sparklin' clear.
    Thanks
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Always shock visible algae?
    Yes, shock.
    You're done SLAMing when:
    Feb 2008
    Denton, TX
    5,061
    You should also be sure that while you are shocking, you need to brush those nooks and crannies that allow algae to hide out with good frequency. Brushing better exposes the algae to the chlorine in the water.
    Mar 2007
    San Rafael, CA USA
    12,082
    If your ladder is removable, then remove it and hit the inside hard with bleach to kill off any algae inside. That should prevent the algae from coming back.
