Results 1 to 16 of 16
Thread: Filling new pool with well water?
    We are getting close to completion on our inground vinyl liner pool. It is a big one. 50' x 32' - 24' free form depth 9' to 42" with bonus shallow cove., roughly 45,000 gallons.
    Our contractor told me I need to line up my water hauling. This is another $2000 I hoped we could avoid. His reasoning is that our well water will take to long and the water will smell like sulphur. Any opinions?
    In-ground vinyl, 49 x 32' -19' -24' "dog bone" shape. 3.5' to 9' depth with 3' deep shallow cove.
    IC 60 salt generator, Intelliflo VS pump, Easy Touch panel, Laminar jets. Prowler Robotic, Stamped concrete.
    Re: Filling new pool with well water?
    I think that the primary issue with the well water quality would be metals. Sulfur smell is caused by hydrogen sulfide, which can be shocked into elemental sulfur and sulfates.
    Unless there are very high levels of hydrogen sulfide, then the sulfur should not be too much trouble.
    What is the fill rate from the well? Do you know what the copper and iron concentrations are in the water?
    South Central NJ
    3,192
    You might line up a 1/2 fill with trucks if the iron, copper, and sediments are too high.
    The 1/2 fill will allow the liner crew to cut in the steps and light(s) and shut the liner vacuum off so as not to disturb your sleep or that of your neighbors. After that, how long it takes is how long it takes.
    Scott
    Owner of - PoolGuyNJ LLC
    Sep 2010
    Noblesville, IN
    104
    That's also a lot of water out of your well. Plus a lot of wear on your pump. I'd truck it in if I were you. 2K on a project the size of yours is small price to prevent headaches.
    16 x 32 15300 gal. IG Vinyl Jandy pump, Jandy sand filter, Paramount circulation system, Automatic pool cover.
    30,107
    Hands down, truck it in unless you have a metal free well and a really high gpm.
    I don't know the quality of our well water, and hadn't considered the wear on our pump. It would be nice to start with clean city water since we are late in the season and want to start enjoying it right away! Did I mention it was 101 here in St. Louis today?
    Thanks!
    I will try to post photos.
    Green1340's Avatar
    May 2011
    Kemp, TX- 50 mi. south of Dallas
    55
    Gina,
    I too have a well and was wanting to fill with the well water. For me the metals were not a problem but the water was extremely hard. The TA and CH were both off the chart. You may want to go ahead and invest in the TF-100 test kit and at least you would know what you are dealing with. I can go with a 60/40 of city/ well water and be ok. You will need the test kit anyway.
    Greenhaw
    Freeform Gunite, 21K Gallons, Gray Plaster, 570 sq. ft., 106 Perimeter.
    Pentair- VS 3050, Intellichlor IC-40, 520 sq. ft Cartridge Filter, Intellibrite LED.
    Sun Touch Controller, Legend Platinum Cleaner with Pentair 1.5 hp Booster Pump.
    2- Bubblers & 2- Deck Jets. Autofill & Overflow. TF-100-Test Kit.
    Jun 2007
    New Jersey
    653
    The stuff about wear on a pump is hype, in most cases, unless you have a really deep well or a small pump. We refilled our 40,000 gallon painted steel pool from a 70-foot deep artesian well every year from 1950 to 2003. Same pump. Same well. 53 years, 54 fills (one year we did it twice due to a broken drain valve) and no problems.
    Our water is metal free and actually tests as too soft for drinking, I was surprised to learn after drinking it all my life. It requires both baking soda and calcium at startup--although I didn't worry about either until we switched to a plaster pool in 2004. Water like that is uncommon from wells, and around here it means you live up in the hills and not down in the flats. But you don't know what you have until you test.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Durk.. (H's name is Dirk... hehe)...
    Pumps from the 50's... lol don't you know they actually made them in the US back then? Forged steel even... now nearly everything is cast and manufactured elsewhere with unknown materials/methods. Most of the pump manufacturers have fled the states by now, it's near impossible to get a pump nowdays with enough US made materials in it to qualify for government specs. Brass is another story... US brass is virtually unheard of anymore.
    Of course that pump worked great for eons! Great Grandpa made it, lol
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Modern well pumps have no problem with filling a pool. I've been working with Italian and Portuguese pumps for years and the only problems come from running them dry and other operator damage.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    I have a well and a deep one at that, 186ft. Filled to the top with water. NO WAY would I fill my pool from it. IF it did run dry you are looking at about 5,000 to 10,000 dollars to drill a new one. Also, pumps aren't built like they used to be. Mine was 6 years old. Came home one night last month from work... NO WATER. Pump died. $1800 for a new one and the plumber... Why take the risk. Yea it might turn out ok... but then again... it might not.
    Cleveland, Ohio
    IG 36,000 gallons. Vinyl Liner, Hayward ProGrid 3620 DE Filter, Hayward Super Pump, Hayward Gas Heater
    Feb 2011
    Petaluma, Ca
    665
    I have a new well drilled in 2003. I just filled my 30000 + gal pool from that. It took 21 hrs. My water is hard but the pool people said it was "really good" water. It is 260' deep with the water at 60'. Comparing my electrical use from normal to the 21 hr it was filling the cost came to approx $100.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Well if it costs $2000 dollars to have water trucked in, and there's an extremely thin chance your pump might give up the ghost and cost you $1800, well isn't it a no-brainer? The only risks I see with using the well water (of any consequence) are over use ( where you draw in sediments from the surrounding water table) and the obvious, metal contamination. So fill the pool slowly and keep an eye on the turbidity of the water, let the well recover if you notice any, and treat for metals in the usual ways (usually sequestrant in the US).
    Thanks everyone.
    It is a vinyl liner pool and my pool contractor states he does not want to hang around for days waiting for my pool to fill, and risk getting wrinkles in the liner. (drama-queen) ! I think we will end up supplementing with well water as the trucks bring in most of the water.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Our well is 456' deep with water beginning at 220' and produces sulfur water, common here. We had water trucked in to fill our pool, accepting it as part of the overall setup and construction expense.
    We use the well water to refill as needed. The hydrogen sulfide is neutralized by the chlorine in the pool so there is no smell. We run the well water for an hour max to avoid depleting the well and haven't had any problems.
    I would not fill an entire pool from a well because it would take way too long and would likely result in wrinkles. Your plan to start with trucked in water and supplementing with well water is sound.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    22,369
    I think you're making the right decision about having the water trucked in. All wells are not created equal and unless you know that your well can handle it and that it doesn't have metals in it, you're doing the right thing.
