Results 1 to 14 of 14
Thread: High chlorine; am I done shocking?
    Jul 2011
    N Isanti Co, MN
    6
    It's been a week since we filled our new pool using well water. I've been monitoring with test strips (very frustrating) and today bought a cheap kit at Walmart until my "real" one arrives from online. Here are my readings:
    TC: 10? (it's orange, but the kit only reads up to 5)
    pH: 7.2
    CYA: 0
    TA: 300
    TH: 300
    I've shocked the pool three times, added a gallon of bleach (my test strips said I had no chlorine), added pH Minus to bring pH down from 8.8, and added 2.5 quarts of metal sequestrant, not all at once. (The water turned coffee-colored immediately after shocking; we have lots of iron in our water. The pool sides & floor are "squeaky", not slimy at all, and the water is clear, just brown.) I've been changing the filter twice a day. Today I can finally start to see the floor! Someone said I should vacuum the floor, but there's nothing down there.
    Question 1: Do I need to shock again to add CYA? I can't find stabilizer/conditioner in my small town. Maybe it's something I can get online. How important is it to get this number up?
    Question 2: Am I adding too much sequestrant? I know the brown water is clean, but I can't stand it! Should I continue to add sequestrant and, if so, how much?
    Question 3: The chlorine seems high. Will it take care of itself, or should I drain some water? I'll test it again tomorrow morning.
    Thanks for your patience with a complete newbie. I promise to pass it on once I know what I'm doing.
    18' x 48" Intex AG pool; 5600 gallons; well water w/iron; 2500-gal Intex filter pump
    Dreaming of blue water.
    Re: High chlorine; am I done shocking?
    cant answer much on the metals deal...
    But Walmart and Lowes carry pool stabilizer {CYA}. Use the Pool Calculator to get your dose, I use 30ppm as the target. Pour the dose into an old sock and tie it in front of the pump discharge, squeeze it often to help things along.
    Sounds like you are right on top of things, I'm sure you;re in for GOOD times!
    Apr 2011
    Lynchburg VA
    393
    Without CYA in your water you are losing your chlorine very very fast. I know Lowe's carries it and I am pretty sure Walmart will as well. You need to get your CYA number somewhere in the 30ppm range and then start shocking your pool until it passes the overnight test. If you CYA is zero, you need to add about 23oz of stabilizer to your pool to bring it up to 30ppm. I cant help with the metals....that way out of my wheelhouse.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    The OTO test is normally used to measure TC levels between 0 and 5. You can, however, use this test to get a vague idea of extremely high TC levels. If the sample turns a particularly vivid yellow the TC level is between 5 and 15, light orange is between 10 and 20, dark orange is between 15 and 30, and brown is 30 or higher.
    With no CYA in the water, your shock level is only 10. So, just let that chlorine level drop down some. With the OTO test, you can use 1 part pool water and 1 part distilled (or non-chlorine) water and then double the test results which will allow you to test to 10.
    Was the water clear when you added it to the pool?
    Stop shocking for now.......
    Let the FC come down below 10 and then retest the pH. Then lower the pH to 7.2ish. This may help the metals sequester.
    Which sequesterant and how much did you use? Name & ingredients & directions on label, please.
    You do need to add about 30ppm CYA to the pool. This is what will protect your chlorine from the sunlight. As mentioned, you can find it at WallyWorld and the big box stores, and, of course pool stores. CYA is a/k/a conditioner or stabilizer.
    You need a little POP, pool owner patience, with clearing the water
    You're done SLAMing when:
    Jul 2011
    N Isanti Co, MN
    6
    Thanks for your quick response, everyone. I didn't realize there was so much to learn!
    Neither Lowe's, Walmart, Menard's or Target had stabilizer/conditioner. There's a pool store about 35 miles away that I can visit tonight.
    This morning's readings are the same as last night's:
    TC: 10/orange
    pH: 7.2
    I guess that's good? No chlorine loss overnight. I keep a solar cover on all the time; don't know if that makes a difference or not. The water temp stays about 82-84 degrees.
    The sequestrant I used is called "Iron Myte" by Utikem, active ingredient Organophosphonic Acid derivative. It says to add 8 oz/4000 gal water, which did absolutely nothing over 3 days. I read on this forum to add much more - up to a quart a day for 4 days - so I then added an additional 2 quarts over 3 days. My pump is running 24/7 with a twice daily filter change. And the water is still brown, but at last it's starting to look like weak coffee instead of strong coffee. Hopefully the trend will continue.
    Sorry, my pool didn't come with POP (Pool Owner Patience). Maybe I can get that at the pool store, too.
    By the way, the water was gorgeous, sparkling clear when we filled the pool. It's the same water we use inside the house - delicious and clean (we soften it for laundry to remove the iron & minerals). We then shocked it, put the solar cover on, and came home from work to revolting brown water.
    WestSidePool's Avatar
    Cincinnati, OH
    424
    I buy my HTH stabilizer/Conditioner from Meijers, if you have one near you.
    Normally kept in the seasonal section.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    Jul 2007
    Chicago, IL
    87
    Your starting FC level may have been above 10, so just because its above 10 now doesn't mean that you didn't lose anything overnight (e.g., you may have gone from 15 to 13).
    I'd leave the solar cover off today to let the sun eat some FC, should happen pretty quickly with no CYA in the water. Once it's below 10, then being down the ph as suggested.
    28K, 20' x 40' IG - Vinyl Liner, Hayward DE Filter, 1.5HP Pump, 250K Hayward BTU Heater, Aquabot Breeze 4WD robotic cleaner
    Jul 2011
    N Isanti Co, MN
    6
    WestSidePool, no Meijers nearby, unfortunately. Such is life in a small Minnesota town.
    Oops - too late to leave the cover off; I'm already at work. The pH is already at 7.2. Do I need it lower than that?
    Butterfly's Avatar
    South Carolina
    10,045
    I suggest you wait about a week (after last addition of sequesterant) before adding any more sequesterant. Just keep pH low -7.2ish - and continue to filter.
    Remove the cover and allow the sun to help lower the FC.
    When you said you shocked your pool, what did you add and how much?
    Jul 2011
    N Isanti Co, MN
    6
    Butterfly, I added granular shock (possibly AquaChem, I could be wrong) and followed directions of 1.3 oz/1,000 gallons, or about 7.5 oz each time.
    I did find a local pool store that has conditioner, and I'll get that tonight after work. Sounds like I need to put it in a sock and drape it in front of the flow valve, correct? Should I just follow the product directions, or do you recommend a certain amount?
    I'll leave the pool cover off. Thanks!
    Run your numbers through the Pool Calculator to get your CYA dose.
    Jul 2011
    N Isanti Co, MN
    6
    Excellent suggestion, ob1. Looks like I'll need to add just over 2# of stabilizer. Thanks!
    Cincinnati, OH
    424
    Just keep in mind that CYA can drop your pH, so you'll want to monitor that.
    I had trouble keeping my pH up and couldn't understand why. Here's my thread regarding that.
    Also, your CYA may take up to a week to read accurate on the test.
    Eric
    Jul 2011
    N Isanti Co, MN
    6
    WestSide, I LOVE your pool pic in your thread! Wow, just beautiful. My pool wants to be just like yours when it grows up.
    Thanks for the heads-up about CYA and pH. Hopefully because my TA is 300, it won't fall too drastically. If it does, I have borax and baking soda at home.
