Thread: pool light housing removal Q
    Diver's Avatar
    May 2011
    South of Boston
    450
    i want to take my pool light housing out so i could do a niche dye test to see if there is any leak there. after reading here it seems like there should be a single screw that would hold an outer ring of the light that keeps the housing in place.
    looking at the picture of my light, i see one screw that is visible thru the opening in the ring on top and one missing screw on the bottom. but it doesn't look like if i remove the top screw that the ring would come off.
    there are 4 round holes in the ring and then there are 10 screws that seem to keep the ring affixed to the liner.
    so looking at all this, i'm somewhat confused how i should remove the housing. the light is made by Hayward, but i don't know specific model. i could take a better look this weekend when i get in the water. this was a shot taken from outside holding my camera in the water. at least i can say that my water is clean
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    Re: pool light housing removal Q
    Remove the top screw and lift the light fixture out. The bottom is secured by a tab that fits into a notch.
    The 10 screws hold the light fixture together. You only remove them when changing the bulb.
    Support the site
    Diver's Avatar
    May 2011
    South of Boston
    450
    cool! i'll give it a try. thanks for responding
