Thread: Any tips on replacing O-ring on DE filter?
    Hi All,
    My FNS Plus has sprung a slight weep at the center o-ring. I bought a replacement oring (which is giant btw). Any tips on replacing it or just install and tighten?
    Joe
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Any tips on replacing O-ring on DE filter?
    Just make sure the grooves are all cleaned out and use plenty of pool lube. It's pretty straight-forward.
    Awesome thanks a ton!
    Mar 2007
    Coastalish 'down easter'
    4,160
    cruz=- please make sure that you double the o-ring over on itself and don't pull overly hard when applying the lube - you don't want to stretch the o-ring!
    Luv& Luk
    -Ted
