Thread: Sifto Salt Question
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Sifto Salt Question
    Thinking about adding salt to my new AGP, we have limited choices for pretty much everything where I live, wondering if anyone has experience using Sifto Crystal Plus.
    It says 99.8% pure evaporated salt but then it also states "inhibits rust build up and stains"......after reading pool school I'm a bit concerned about that last one.
    Thanks.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Sifto Salt Question
    I think that should be OK. The rule of thumb is 99.4% pure or better.
    Jun 2017
    Ottawa/ON, Canada
    65
    Did it work out ok?
    12'x24' Aqualeader Sentinelle 54" deep AG (7000 gallons/ 26,500L) - Jandy jxi 260,000 btu gas heater, Hayward Aquatrol salt system (SWG). nature2 water purifier. 1.5hp pump/ 22.5" sand filter. Install July 2017. Taylor 2600 test kit. Solar cover and reel.
