Results 1 to 11 of 11
Thread: My water feels sticky
    Ok so everybody in my circle of friends and family thinks I am crazy. The pool is sparkling blue. You can see a potato bug at the bottom of the 10ft deep end and it sparkles in the light... but I am convinced it feels sticky! When I get on my float instead of sliding across it, you stick. Chemicals are perfectly balanced. I was thinking this could be low PH but PH is 7.6. Calcium Hardness perhaps?? Borates?? How can I make my water feel silky?? Am I just nuts??
    Cleveland, Ohio
    IG 36,000 gallons. Vinyl Liner, Hayward ProGrid 3620 DE Filter, Hayward Super Pump, Hayward Gas Heater
    Butterfly's Avatar
    South Carolina
    10,045
    Re: My water feels sticky
    Can you post a full set of test results?
    You're done SLAMing when:
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Some people add salt to their water to make it feel better. I did do that one year and I liked the results... on my list of things to do again this year.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    Feb 2011
    Sicklerville, NJ
    80
    I have salt @3200 ppm and borates @30 ppm and it's almost too soft and silky.
    25k gal Lazy-L, vinyl liner, poly walls, swimout spa, diving board, TurboTwister slide.
    Hayward 2HP 2-spd pump, Pentair 2HP spa pump, Hayward 30" 500lb sand filter.
    Goldline Pro Logic PS-8 automation/SWG. 2 LED ColorLogic 4.0. 8 Jandy deck jets. MX-8 cleaner.
    I dont have a full set of test results right now. I am at work... How would I add salt? I do not have a SWG as this is a chlorine pool. Add salt to the skimmer? I have a water softener so I am very familiar with that.
    Cleveland, Ohio
    Sep 2009
    Frederick County, MD
    184
    Just dump it in the pool and stir it around a little with your pool brush. You should get some salt strips to you do not put too much in.
    Here is an earlier thread...... can-you-add-salt-t6006.html
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
    Can it be added to the skimmer? I purchase salt for my softener all the time but it comes in big pellets... about the size of a ping pong ball squished to an oval... I wouldnt want to just add those to my pool. I have never seen small crystals.
    Cleveland, Ohio
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Best added directly to the pool water... it will fall to the floor and dissolve in a few hours. I bought mine at the home depot, it was in a blue bag and relatively inexpensive.
    27' round AG
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    The pellets are fine, you just need to make sure that they don't have any additives (like anti-rust ingredients, etc). They will dissolve very quickly, especially if you swim and kick them around, which is kind of fun anyway. They are cold as they dissolve, so swimming with them is an interesting experience.
    Honestly though, it sounds to me like your water and your floats are "squeaky clean". Slick and slimy is bad.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    You could use a pool net to get the sticks out
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    Bluegrassman's Avatar
    Jan 2012
    West KY
    243
    A little late, I know but..
    When I had to add additional salt to my pool, I had the kids (teenagers) go swimming to help stir it up. I did tell them NOT to open their eyes under water that day just to avoid geting any salt crystals in their eyes. Within an hour or two, it appeared to all be dissolved.
    18x36 Vinyl IG ~27,000 gal, Intelliflo VF Pump, 300# Sand Filter, Polaris 280 w/Pentair Booster Pump, Pentair EasyTouch w/ IC40 SWCG
    TF100 Test Kit
    SpeedStir
