Thread: Pump getting hot
    kcjonz's Avatar
    Mar 2010
    Charlotte, NC
    26
    Pump getting hot
    I've seen some discussions on here regarding pumps over heating but still can't determine if mine is shot. I have a AO Smith B945 dual speed motor. Today I came home and it was not running during a scheduled run time. It heard it clicking trying to turn back on. It was extremely hot. It will start run for 4-5 seconds then shut off on high. It will start up and run for 20-30 minutes on low, but has a burning electrical smell. After it shuts off then cools down, you can hear a click in the motor at which point I can turn it back on.
    I checked voltage at the Intermatic controller and everything seems fine.
    Any ideas if this may be capacitor(s), impeller or just a totally bad motor. Or simply the heat outside which in the high 90s with 70-80 humidity. I just bought the house 2.5 years ago and I'm guessing the pump is at least 7-8 years old.
    ____________________________________________
    18 x 36 IG Vinyl (28,000 G), AquaRite Goldline T15 SWG, Intermatic PE153, 1/6 - 1 HP Pump, Triton Sand Filter, TigerShark QC
    22,553
    Re: Pump getting hot
    It sounds like the motor has failed and is tripping the thermal overload. You can try replacing the capacitor but if it's happened a few times it's most likely got the windings. I'd just replace the motor in kind and then you know it'll be fine.
    kcjonz's Avatar
    Mar 2010
    Charlotte, NC
    26
    Thanks for the reply. I was thinking the same thing. Especially since I have no idea how old the motor is. I kind like the piece of mind to know about my equipment, I think that might be worth the couple hundred dollars for the new motor.
