Thread: Pentair IC 20 fuse keeps blowing
    I have SWG and was working fine until last month. I noticed that the fuse was blown, so I replaced it and started the pump. the lights indicator would come on and then after a few seconds the fuse would blow up again (the lights turned off). it was working great before but now my pool is not getting the chlorine and turning murky (adding my own chlorine until I get this fixed). any ideas or help? thanks in advance.
    27'x54" Matrix Resin - 200lb Pentair sand filter - 1.5hp Pentair optiflow 2 speed pump - Aquatrol SWG - Gorilla Pad
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    417
    Re: Pentair IC 20 fuse keeps blowing
    Check your ground wire and other wire connections to the power center.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
