Thread: Advice needed: Jandy Aquapure Ei or 1400
    I have a 21,000 gal pool in Texas with all Jandy equipment and need to replace the broken AutoClear Plus SWG. I am contemplating on purchasing the Jandy Aquapure Ei or 1400 model SWG so that I can hook either of them to my existing Aqualink RS system and control from inside the house. I have not seen much feedback in regards to the Aquapure Ei model. What is your advice? The cost difference is about $150 between the two with the 1400 model being higher. Thanks in advance.
    22k gal, IG Plaster, 2 HP Jandy Stealth, DE filter, Polaris 280 Cleaner, Spa, Water feature
    Re: Advice needed: Jandy Aquapure Ei or 1400
    I think only the 1400 can be controlled via Jandy controls system. The Ei series does not tie into Jandy controls - stand alone only.
    The Ei is designed to be installed by homeowners, while the 1400 requires minor plumbing. I prefer the proper plumbing of the 1400, rather than the pipe clamp design of the Ei, but if PVC plumbing bothers you the Ei has that advantage.
