Thread: Suntouch turning solar off when solar heat is available
    I am using a Suntouch Controller to control my solar heating. It works fine most of the time - but sometimes seems to turn off when water temperature is below the taget and solar heat is available.
    I have it set for default Heat Start Differential 6 degrees and Heat Stop differential 3 degrees - however it seems to be switching off when the differential reaches 6 degrees (not 3 degrees). e.g. water temp 85F, pool temp target 88F, solar collector temp 90F and solar turns off.
    Anyone else using a Suntouch seeing similar - or have ideas what I might be doing wrong.
    Sticky's Avatar
    Oct 2009
    WoyWoy Australia
    90
    Re: Suntouch turning solar off when solar heat is available
    hi I have the suntouch and I found the instructions ah lets say difficult , why do they have these differentails other cotrollers I ve have you just set the temp of the pool and it ran till the water reach that temp as long as the solar collector was hot enough , I remember another thread here on the Suntouch explianing what they mean by Start Differential and Heat Stop differential .
    7 meter by 2 Meter pebblecrete , VF intelliflo , Pentair ECO-CHLOR 25 , 5 helicol Sunx 40 solar panels & a Associated controls solar controller with an intellicom 3 to control the VF and relay to switch to valves .
