Thread: Salt Loss
    lynns's Avatar
    Jun 2010
    New Jersey
    50
    Salt Loss
    How much salt loss is normal? I know that is a hard question to answer. The pool is used only about 3 times a week (no kids splashing). Last year I didn't have to add salt at all but this year it seems to be lowering about 100ppm per week and I have to add some.
    14x30 Viking "Santa Barbara" Fiberglass Pool 12,500 gallon
    IntelliFlo Variable Speed Programmable Pump
    Salt Water Generator with AquaRite Electronic Chlorinator
    Pentair Clean and Clear Cartridge Filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Salt Loss
    Are you getting your reading from test strips or the SWCG readout? Do you have an autofill device?
    lynns's Avatar
    Jun 2010
    New Jersey
    50
    Re: Salt Loss
    I get the reading from the SWCG. We do not have autofill.
    SW Indiana
    9,198
    Re: Salt Loss
    Quote Originally Posted by lynns
    I'd consider an alternative test method to double check the SWCG reading. Other things can influence their readings and they often give strange readings.
    Re: Salt Loss
    How old is the cell? It would also be good to do a visual inspection of the cell to see if there is any white crusty buildup on the cell. Older cells start to read the salt level as lower than it actually is when they are starting to fail due to old age. Also calcium buildup on the cell plates can cause it to mis-read the salt level.
    lynns's Avatar
    Jun 2010
    New Jersey
    50
    Re: Salt Loss
    I'll try using the strips to check the salt. This is the second summer for the cell (and pool). The "inspect cell" light had come on recently but I read in the manual that it comes on automatically after 3 months.
