Thread: Adding a Jandy Automated Valve to Aqualink RS
    Hey guys, need some expert opinion here!
    I have a Jandy Neverlube valve that diverts water flow to a dedicated line for a Polaris 360. I also have an Aqualink RS with several available AUX buttons. How would I go about installing an automated switch onto the current Neverlube valve and interfacing it with the Aqualink control center?
    Thanks!
    -Tom
    17,000 gal plaster with spa. Pentair Clean & Clear cartridge filters. Jandy systems with Aqualink RS and Polaris 360.
    Pool Store free since May 2011!
    Re: Adding a Jandy Automated Valve to Aqualink RS
    The AquaLink RS is designed to control a couple of valves using valve actuators, without using up an aux relay. See here and your AquaLink RS manual.
    I'll have to grab a PDF of the Aqualink RS manual. The buy that installed this panel before I moved in didn't leave it.
    It's not that I want to set the valve itself to the AUX botton. It's that I want the AUX button to start the Polaris 360. So I push Aux, this valve turns and the water flow is directed into the sweeper pipe. Thanks for the link, I'll keep reading.
    -Tom
    This is probably the manual for your unit, though there is some chance that you have a slightly different model.
    What you want to do is a standard feature of the AquaLink RS. There are a couple of steps to get it all working, but it isn't really difficult.
