Thread: Best cleaner for l-shaped pool with bird droppings
    The plumbing in my pool was just redone and as part of it I had them install a Polaris line in the event I wanted one for the future. I have fairly large l-shaped pool which can be seen in the picture below:
    download/file.php?id=12422
    Issues that I have had in the past are constant bird dropping in the bottom of the pool and debris sticking to the walls at the water line.
    I am now trying to decide if I would be better off going with a robotic cleaner or a polaris to keep my pool clean and at the same time be able to get the bird droppings and water line debris.
    I have been researching and researching this and some people love the ease of use of the polaris while others state that the robots are the best way to go. Even more confusing, even though the Polaris 280 is not the most powerful Polaris, it comes highly recommended over the other ones.
    So I am really confused as to what I should do here. My budget is around $1,600 and if I went with the Polaris there would be signficant savings, but my main goal is to do what is best for keeping the pool clean rather than saving the $$$.
    With a pool my size and shape, can anyone provide some advice?
    ~40k gallon IG vinyl pool, Pentair 3HP <Not sure specific model>, Hayward Micro Clear DE4800, Polaris 380 Cleaner, Polaris Halcyon Booster Pump, Polaris Auto Clear Plus 1700 SWG.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Best cleaner for l-shaped pool with bird droppings
    With a pool that big, I think I would go with a robot. Hopefully some people with more experience will stop by.
