Thread: Return Eye, How are you directing yours.
    johnnysnok's Avatar
    Feb 2011
    South Jersey
    192
    How are you directing your return eye?
    1-pointing up to make waves in your water?
    2-pointing down a little to make little ripples?
    3-pointing down to clear the bottom with no top water movement?
    I was just wondering if there was a right or wrong way. I'm sure it would also depend on your pools shape.
    Your thoughts?
    Dough Boy 12' x 24' Oval
    Wedding Cake Steps
    1500 SF Timber Tech Composite Decking
    Video of my pool and retaining wall....Above Ground Pool Ideas - YouTube
    Jul 2010
    Mickleton, NJ
    229
    Re: Return Eye, How are you directing yours.
    I'm not sure what is right or wrong, maybe someone will come along and school us.
    I change mine around some, when I'm adding bleach I first turn it a little up to be sure the bleach is mixing in with the return flow.
    If I have dirt on the floor I'll turn it to the floor to mix it up to the surface.
    If I am clean on the floor (most often) I point it to the right, a little up to keep the surface moving so anything that lands in the pool flows to the skimmer. Skimmer is to the left of the return.
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Pretty much the same practice for me as well:
    - down to the right most of the time (skimmer is to the left)
    - when my daughter is swimming I'll point it up a bit to make some current
    - when I add bleach I'll point it up for a bit, then move it back down before putting the solar blanket on
