Thread: Calling all pool Wizards! Will we swim again? Jet Pipe Broke
    So here's the 411, I have a 22 x 40 vinyl liner pool. We noticed the water dropping a couple months ago and just haven't been able to find the leak until this weekend. Our autofill has been doing a good job of keeping the pool filled in the meantime, but the water bill is killing us. So the leak appears to be where the pipe (2") broke off by the fitting where one of our jets is located. It is behind the pool wall and underneath our concrete patio. I imagine the ground settling caused pressure on it and it broke off. It is where I can reach it with my fingers. My question is, does anyone know of an easy way to fix this? I only see this becoming hugely expensive! Concrete cutting, removal of the pipe, etc.... Is there an easier way? Pipe putty? Sealing the pipe off and not using ti? Help!
    20x4 Intex Ultra Frame Round, 2650gph sand filter and loving it!!
    Jul 2011
    Myrtle Beach, SC aka Redneck Riveria
    125
    Re: Calling all pool Wizards! Will we swim again? Jet Pipe B
    You can't really plug it off, because all the returns are looped together.
    When you say you can reach it with your fingers, are you referring to from inside the pool? How much concrete is on the deck where the return is located? It is possible to cut a 2' x 2' square and dig down and replace it. If it's like some of the pools I take care of & only has a 3' deck around the edges, you can dig under the concrete, make the repair & replace the dirt (Please compact the dirt as much as humanly possible to prevent the concrete from cracking.
    You can try an AB two part Epoxy. It sets underwater. But I'd recommend shutting the pump off a few hours to give it time to set up.
    "When your pool is sick, call the doctor, I make house calls"
    One stop pool shop, I do everything but install them. 9+ years of experience.
    Yes, I can reach it from inside the pool by sticking my finger here the jet and pipe is. I believe the concrete is about 3"x3". I ca isolate off that pipe because we have pickets of where the pipe converge together by the pump. Would you still not recommend that? Thanks for your help too.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    If you can isolate that pipe and cap it off it should be fine. Cap it off where the pipes converge and put a plug in the return fitting.
    Love TFP? Become a
    TFP Supporter!
