Results 1 to 7 of 7
Thread: My filter
    My filter
    Hey there..i have noticed that my pool fliter runs fine...once a week i throw a bag of shock in it to maintain it...i have noticed that after i put the shock in....even while i am pouring it in slowly..i notice the psi jumps from 10-13 to about 20 psi....
    I then bump the filter and it has been working fine..should i be worried..??
    I have a hayward filter/pump for an above ground pool.
    The model number for the pump is sp1580Z2
    I have had it for 5 yrs..and the previous owner had it ..but i dont know for how long.../......
    thanks to everyone for their help...
    Donldson's Avatar
    NW Ohio
    2,884
    Re: My filter
    Welcome to the forum spock!
    I wouldn't be too worried about the PSI, but if you are adding the shock to the skimmer you might want to change that. Best is slowly pour it slowly in front of the return so it quickly gets dilluted into the rest of the water.
    On a related note, is there a specific reason you are putting a bag of shock weekly? And also if you could put in your signature some specs about your pool (size, pump, filter, chlorinating method) it will help the experts here to give you more accurate answers to questions when you have them.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    30,405
    Re: My filter
    For discussion purposes here on the forum, you cannot buy "shock". Shock is a verb and it is a process, not a product.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Re: My filter
    Pool Shock is also a product: http://www.amazon.com/Swim-Chlorine-Poo ... 715&sr=8-1
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    Jul 2007
    Chicago, IL
    87
    My filter
    Of course the pool stores and Internet retailers sell stuff called "shock". However, it's always granular chlorine plus something else. It's the something else that usually won't help and will likely cause more side-effect problems, (green hair,sky high CYA levels, etc,).
    Chlorine does the job and we'd prefer to get that from liquid chlorine/bleach without getting anything else. Shocking is the process of bringing the FC level up to the point where any and all organics are killed and holding it there as long as necessary.
    28K, 20' x 40' IG - Vinyl Liner, Hayward DE Filter, 1.5HP Pump, 250K Hayward BTU Heater, Aquabot Breeze 4WD robotic cleaner
    30,405
    Re: My filter
    For discussion purposes on the forum, it is helpful if we make the distinction and refer to shock as the process. It is generally confusing if you refer equally to a product carrying the same name.
    You can, of course, nit pik that if you like but it is not helpful to the new people who are trying to learn.
    Donldson's Avatar
    NW Ohio
    2,884
    Re: My filter
    I understand that Dave, and I agree. I was just trying to find out more about the problem before I found out whether he was using cal-hypo or dichlor, since the answer to that could make for a whole other discussion.
